I create a number of ScatterSeries in code for various ice cream flavors (may not be relevant) like so:
ScatterSeries ss = new ScatterSeries();
// various properties set which probably don't matter for the discussion
TextBlock tb = new TextBlock();
tb.SetBinding(TextBlock.TextProperty, new Binding("Item.ToolTip"));
ss.ToolTip = tb;
The ToolTip property in the underlying data is the flavor of the ice cream represented by the series. I expect that when I mouse over a point on the chart, the user will see the ToolTip for that point and tell them the flavor of ice cream (along with the series badge).
The behavior that I see is that when I first hover over a point on the first series (first meaning the first one I hover over - doesn't matter which one I choose - in this case I chose the Chocolate Chunk series) the tooltip pops up like so:
I expect this one to look like so (though it would be a different flavor):
It will, however, pop up correctly once I've moused over the point on a different series.
Again, doesn't matter which series I choose - the first point I hover over will be blank (with the series badge displayed but no flavor text) until I hover over a point on a different series. If I were to hover over a bunch of points all from the first series, they all exhibit this behavior, once I hover over a point from a different series, then tooltips are OK for the points in the first series.
Ideas?
Matt
Thanks Francis. I'm really impressed with the level of attention the Infragistics team has to issues/concerns. A lot of other companies could learn from this.
itsmatt, I have created a support case and linked it to Development Issue 61154 so you will be notified when this fix is addressed.
My apologies for not being able to reproduce this before. I am now able to reproduce the issue you are seeing and have logged a bug for it. If you'd like to keep track of this issue, the bug number is 61154.
Marisa
Hi there,
I was unable to reproduce the issue you are experiencing in a test project of my own. Would it be possible for you to attach a test project exhibiting the behavior you're seeing so I can investigate this further?
Thank you,
