558
SubGrid Management in C#
I'm trying to build something similar to this link, but instead of using the XAML to define the FieldLayouts and their settings.  However, I'm not able to get it to reproduce it.  Every time I try to define the FieldLayouts in my event handler for AssigningFieldLaoutToItem, it fails to realign itself.  It's further complicated by the fact that I have an N-tiered dataset.  Any help would be greatly appreciated.
Kyle
  • 138253
    Hello Kyle,
    It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post and I can say that the FiledLayout that you assign to an item should be added in the XamDataGrid’s FieldLayputs collection and have a Key to work properly.
  • 558
    Also, when I add an event handler for the Loaded event on the grid which expands all rows (grd.Records.ExpandAll(true)), the columns no longer align.  I know I need to fire off an event, but I'm not sure which one.  I also would have expected the expand all to fire off the resize event but that does not seem to be true either.
    Kyle
