25
Databinding Linechart to a collection (and dynamically changing the binding)
I can databind linechart to custom IEnumerable collection, this is done with ObjectDataProvider in XAML like this:
In <Window.Resources>:
<ObjectDataProvider x:Key="PatientData" ObjectType="{x:Type local:PatientDataReader}" MethodName="GetData"/>
In <XamChart>:
<igCA:Series ChartType="Line"
StrokeThickness="3"
DataSource="{Binding Source={StaticResource PatientData}}"
DataMapping="Label=Name; Value=Age">
</igCA:Series>
However, now need to change the binding in runtime, it requires code in C# code-behind file.
How is this done? Should I use DataContext or what?
-pom-
  • 25
    Ha! Sometimes one just comes up with the solution right after the question is asked.
    This is the solution in the code behind:
    ObjectDataProvider provider = (ObjectDataProvider)this.FindResource("PatientData");
    provider.MethodName = "GetData2";
    This will dynamically change the method on the bound object to another! Not actually XamChart feature but a general WPF feature.
    -pom-
  • 739
    To change data source in runtime DataSource and DataMapping properties have to be set. The DataSource property just needs a reference to your collection in runtime:
    private void Button1_Click(object sender, RoutedEventArgs e)
       this.xamChart1.RefreshEnabled = false;
       this.xamChart1.DataSource = myCollection;
       this.xamChart1.DataMapping=” Label=Name; Value=Age”;
       this.xamChart1.RefreshEnabled = true;
    GoranS
