When XamCarrouselListBox is hosted in xamTile strange behavior occurs while resizing. In some moment XamCarrouselListBox’s items’ path is not properly resized. Found so far is that tile’s constrains affect the moment (size) when problem occurs. In attached test solution the problem can be reproduced when you maximize the window.We are using version 10.3.20103.2018. We have not experienced such issue with version 10.2.20102.1014.Find attached demo solution (you have to set path to your sample pictures folder on your Windows (e.g. “C:\Users\Public\Pictures\Sample Pictures”) in Window1.xaml.cs:27
Steps to reproduce:1. Maximize window2. Maximize tile – path takes all XamCarrouselListBox3. Make tile normal size4. Path in XamCarrouselListBox takes only part of the tile
Hi Ivan,
Just wanted to let you know that your issue has already been fixed internally and you will be able to download the fix in the next Service Release. You can check this page from our website for upcoming releases: http://ko.infragistics.com/support/documentation.aspx#ServiceReleases
Please let me know if you require any further assistance on the matter or verify the thread as resolved so it would help other users.
Sincerely,
Petar Monov
Developer Support Engineer
Infragistics Bulgaria
www.infragistics.com/support
Hello Ivan,
One of our quality engineers has been investigating this issue for you and has been able to reproduce the behavior you describe. As a result she has logged a development issue with number: 61605 to be fixed internally. I have just created a support ticket on your behalf with id: CAS-58106-KM878Q in order to link the development issue to it, so that you are automatically updated when a Service Release containing your fix is available for download on our website: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads .
Please let me know if you require any further assistance on the matter.
