Hi Infragistics,
I'm trying to investigate an infinite loop issue which seems to be happening inside Infragistics XamDataGrid. We have a functionality in our app that let's the user to save and load various customisations he made in his XamDataGrid including FieldLayouts. I can't really tell you what exactly has happened under the cover, but XamDataGrid ended up persisting an inconsistent state of FieldLayouts which looks like this in XML format. Using SaveCustomizastions() method.
<GridLayout name="andor1" type="User"> <Option> <xamDataPresenter version="10.1.20101.2018" formatVersion="1.5"> <fieldLayouts> <fieldLayout key="" fieldList="RowStatus;ResultDataRowStatus, [...]"> <sortedFields> <sortedField direction="Ascending" fieldName="DealStartDate" isGroupBy="false" /> </sortedFields>
<fields> <field name="RowStatus" FixedLocation="FixedToNearEdge" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" row="0" column="36" rowSpan="1" columnSpan="1" isCollapsedInLayout="false" />[...] </fields> </fieldLayout> <fieldLayout key="" fieldList=""> <parentFieldLayout key="" fieldList="RowStatus;ResultDataRowStatus, [...]" /> </fieldLayout> </fieldLayouts>
What I really don't like in this is that the 2nd layout refers to a parentLayout which has the same <empty> key and using the same key for different layout really smells like an infitine loop root cause here.
Loading the above XML works fine with LoadCustomisations() method, but various other functionality stops working. For example setting the EditorStyle of a field in code causes the application to hang forever.
Here's the call stack I got from debugger for that call:
Infragistics3.Wpf.DataPresenter.v10.1.dll!Infragistics.Windows.DataPresenter.GroupByAreaMulti.SynchronizeFieldLayouts(bool calledFromApplyTemplate) + 0x218 bytes Infragistics3.Wpf.DataPresenter.v10.1.dll!Infragistics.Windows.DataPresenter.GroupByAreaMulti.OnStyleVersionNumberChanged() + 0x7 bytes Infragistics3.Wpf.DataPresenter.v10.1.dll!Infragistics.Windows.DataPresenter.GroupByAreaBase.OnStyleVersionNumberPropertyChanged(System.Windows.DependencyObject target, System.Windows.DependencyPropertyChangedEventArgs e) + 0x20 bytes WindowsBase.dll!System.Windows.DependencyObject.OnPropertyChanged(System.Windows.DependencyPropertyChangedEventArgs e) + 0x4a bytes PresentationFramework.dll!System.Windows.FrameworkElement.OnPropertyChanged(System.Windows.DependencyPropertyChangedEventArgs e) + 0x50 bytes Infragistics3.Wpf.DataPresenter.v10.1.dll!Infragistics.Windows.DataPresenter.GroupByAreaBase.OnPropertyChanged(System.Windows.DependencyPropertyChangedEventArgs e) + 0x27 bytes WindowsBase.dll!System.Windows.DependencyObject.NotifyPropertyChange(System.Windows.DependencyPropertyChangedEventArgs args) + 0x2c bytes WindowsBase.dll!System.Windows.DependencyObject.UpdateEffectiveValue(System.Windows.EntryIndex entryIndex, System.Windows.DependencyProperty dp, System.Windows.PropertyMetadata metadata, System.Windows.EffectiveValueEntry oldEntry, ref System.Windows.EffectiveValueEntry newEntry, bool coerceWithDeferredReference, System.Windows.OperationType operationType) + 0x515 bytes WindowsBase.dll!System.Windows.DependencyObject.SetValueCommon(System.Windows.DependencyProperty dp, object value, System.Windows.PropertyMetadata metadata, bool coerceWithDeferredReference, System.Windows.OperationType operationType, bool isInternal) + 0x1eb bytes WindowsBase.dll!System.Windows.DependencyObject.SetValue(System.Windows.DependencyProperty dp, object value) + 0x2e bytes Infragistics3.Wpf.DataPresenter.v10.1.dll!Infragistics.Windows.DataPresenter.GroupByAreaBase.StyleVersionNumber.set(int value) + 0x24 bytes Infragistics3.Wpf.DataPresenter.v10.1.dll!Infragistics.Windows.DataPresenter.DataPresenterBase.BumpGroupByAreaStyleVersion() + 0x24 bytes Infragistics3.Wpf.DataPresenter.v10.1.dll!Infragistics.Windows.DataPresenter.Field.ProcessFieldSettingsPropertyChanged(System.ComponentModel.PropertyChangedEventArgs e, Infragistics.Windows.DataPresenter.FieldSettings settings, object settingsOwner, bool firstPassForPresenterFlag, bool firstPassForFieldLayoutFlag, Infragistics.Windows.DataPresenter.Field field, Infragistics.Windows.DataPresenter.FieldLayout fieldLayout, Infragistics.Windows.DataPresenter.DataPresenterBase presenter) + 0xc61 bytes Infragistics3.Wpf.DataPresenter.v10.1.dll!Infragistics.Windows.DataPresenter.Field.OnSettingsPropertyChanged(object sender, System.ComponentModel.PropertyChangedEventArgs e) + 0x55 bytes Infragistics3.Wpf.v10.1.dll!Infragistics.Windows.Helpers.DependencyObjectNotifier.RaisePropertyChangedEvent(string propertyName) + 0x3a bytes Infragistics3.Wpf.DataPresenter.v10.1.dll!Infragistics.Windows.DataPresenter.FieldSettings.OnPropertyChanged(System.Windows.DependencyPropertyChangedEventArgs e) + 0x31 bytes WindowsBase.dll!System.Windows.DependencyObject.NotifyPropertyChange(System.Windows.DependencyPropertyChangedEventArgs args) + 0x2c bytes WindowsBase.dll!System.Windows.DependencyObject.UpdateEffectiveValue(System.Windows.EntryIndex entryIndex, System.Windows.DependencyProperty dp, System.Windows.PropertyMetadata metadata, System.Windows.EffectiveValueEntry oldEntry, ref System.Windows.EffectiveValueEntry newEntry, bool coerceWithDeferredReference, System.Windows.OperationType operationType) + 0x515 bytes WindowsBase.dll!System.Windows.DependencyObject.SetValueCommon(System.Windows.DependencyProperty dp, object value, System.Windows.PropertyMetadata metadata, bool coerceWithDeferredReference, System.Windows.OperationType operationType, bool isInternal) + 0x1eb bytes WindowsBase.dll!System.Windows.DependencyObject.SetValue(System.Windows.DependencyProperty dp, object value) + 0x2e bytes Infragistics3.Wpf.DataPresenter.v10.1.dll!Infragistics.Windows.DataPresenter.FieldSettings.EditorStyle.set(System.Windows.Style value) + 0xc bytes > >>> Our code <<<The only workaround I've found so far is keeping only the first layout before persisting the state of the grid.
Andor Molnar
HI,
I am just following up on this forum post.
Please let me know if you need further assistance.
Sincerely,
Matt Developer Support Engineer
Hi Andor,
I tried to duplicate your issue, but was unable to.
Your saved layout doesnt look right. Some Key attributes are missing., some type information on the date field.
Here an example of what the SaveCustomization should save.
<?xml version="1.0" encoding="utf-8"?><xamDataPresenter version="10.1.20101.2060" formatVersion="1.6"> <fieldLayouts> <fieldLayout key="Person" fieldList="RowStatus, ResultDataRowStatus, DealStartDate;DateTime, Name, Quantity, Married;Boolean, DOB;DateTime, ID;Int32, Address1, City, State, Zip, Cars;ObservableCollection`1"> <sortedFields> <sortedField extendedInfo="DealStartDate;DateTime" direction="Ascending" fieldName="DealStartDate" isGroupBy="false" /> </sortedFields> <fields> <field name="RowStatus" extendedInfo="RowStatus" FixedLocation="FixedToNearEdge" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" row="0" column="0" rowSpan="1" columnSpan="1" isCollapsedInLayout="false" /> <field name="ResultDataRowStatus" extendedInfo="ResultDataRowStatus" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" row="0" column="1" rowSpan="1" columnSpan="1" isCollapsedInLayout="false" /> <field name="DealStartDate" extendedInfo="DealStartDate;DateTime" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" row="0" column="2" rowSpan="1" columnSpan="1" isCollapsedInLayout="false" /> <field name="Name" extendedInfo="Name" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" row="0" column="3" rowSpan="1" columnSpan="1" isCollapsedInLayout="false" /> <field name="Quantity" extendedInfo="Quantity" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" row="0" column="4" rowSpan="1" columnSpan="1" isCollapsedInLayout="false" /> <field name="Married" extendedInfo="Married;Boolean" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" row="0" column="5" rowSpan="1" columnSpan="1" isCollapsedInLayout="false" /> <field name="DOB" extendedInfo="DOB;DateTime" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" row="0" column="6" rowSpan="1" columnSpan="1" isCollapsedInLayout="false" /> <field name="ID" extendedInfo="ID;Int32" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" row="0" column="7" rowSpan="1" columnSpan="1" isCollapsedInLayout="false" /> <field name="Address1" extendedInfo="Address1" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" row="0" column="8" rowSpan="1" columnSpan="1" isCollapsedInLayout="false" /> <field name="City" extendedInfo="City" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" row="0" column="9" rowSpan="1" columnSpan="1" isCollapsedInLayout="false" /> <field name="State" extendedInfo="State" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" row="0" column="10" rowSpan="1" columnSpan="1" isCollapsedInLayout="false" /> <field name="Zip" extendedInfo="Zip" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" row="0" column="11" rowSpan="1" columnSpan="1" isCollapsedInLayout="false" /> <field name="Cars" extendedInfo="Cars;ObservableCollection`1" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" row="0" column="12" rowSpan="1" columnSpan="1" isCollapsedInLayout="true" /> </fields> <recordFilters /> </fieldLayout> <fieldLayout parentFieldName="Cars" key="Car" fieldList="Make, Year;Int32, Model"> <parentFieldLayout key="Person" fieldList="RowStatus, ResultDataRowStatus, DealStartDate;DateTime, Name, Quantity, Married;Boolean, DOB;DateTime, ID;Int32, Address1, City, State, Zip, Cars;ObservableCollection`1" /> <fields> <field name="Make" extendedInfo="Make" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" /> <field name="Year" extendedInfo="Year;Int32" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" /> <field name="Model" extendedInfo="Model" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" /> </fields> </fieldLayout> </fieldLayouts></xamDataPresenter>
I will probably need a small sample application that duplicates this issue.
Hi Matt,
You can find the saved customizations at the beginning of my original post. I've only cut some of the fields from it to make the long lines shorter.
Andor
Can you attach a copy of the saved customizations. A small isolated sample replicating this issue would be best. Sincerely, Matt Developer Support Engineer
I will give it a try, but not really sure I'm able to reproduce the problem in a sandbox. There're a lot of stuff (event handlers, bg processing, etc.) happening under the cover and to be honest I haven't managed to get to the bottom of it. To put it in a nutshell, I have no idea how and where that extra FieldLayout gets generated.
After all, shouldn't XamDataGrid protect itself against such scenarios, at least at the time where the invalid layout is being added?
