When I run the attached Xaml, the application does not match the design view. The design view shows the bitmap. The app shows nothing. Why is that?
Hi WayneMiller,
I am not sure where you want to put this image, but if you want the image bellow the ribbon try this code (for me it is showing the image under the ribbon, when running the application):
<igRibbon:XamRibbonWindow x:Class="WpfAppTest.MainWindow" xmlns=http://schemas.microsoft.com/winfx/2006/xaml/presentation xmlns:igRibbon=http://infragistics.com/Ribbon xmlns:x=http://schemas.microsoft.com/winfx/2006/xaml Title="MainWindow" Height="391" Width="526" xmlns:my="clr-namespace:Infragistics.Windows.Ribbon;assembly=InfragisticsWPF4.Ribbon.v10.3" > <igRibbon:RibbonWindowContentHost> <igRibbon:RibbonWindowContentHost.Ribbon> <my:XamRibbon Name="ribbon" DockPanel.Dock="Top" Theme="Scenic"> <my:XamRibbon.ApplicationMenu> <my:ApplicationMenu Caption="Some App" /> </my:XamRibbon.ApplicationMenu> <my:XamRibbon.QuickAccessToolbar> <my:QuickAccessToolbar /> </my:XamRibbon.QuickAccessToolbar> <my:RibbonTabItem Header="Home"> <my:RibbonGroup Caption="Clipboard" /> </my:RibbonTabItem> <my:RibbonTabItem Header="Insert" /> </my:XamRibbon> </igRibbon:RibbonWindowContentHost.Ribbon> <igRibbon:RibbonWindowContentHost.Content> <Image Name="viewer3D" Stretch="None" Source="/Images/ZoomedIn3D.png" /> </igRibbon:RibbonWindowContentHost.Content> </igRibbon:RibbonWindowContentHost></igRibbon:XamRibbonWindow>
