515
show control in field.header
i have this code:
xaml: <igDP:XamDataGrid Name="XamDataGrid1"/>
 vb:
Public Class CViewmodel
Public ReadOnly Property FieldName As String
Get
Return "FieldValue"
End
Get
End Property
End Class
Private Sub MainWindow_Initialized() Handles Me.Initialized
Me.XamDataGrid1.DataSource = New CViewmodel() {New Viewmodel, New CViewmodel, New CViewmodel }
End Sub
Private Sub DataGrid_FieldLayoutInitialized() Handles _  XamDataGrid1.FieldLayoutInitialized
For Each aField As Field In e.FieldLayout.Fields
Dim aLabel As New TextBlock
aLabel.Text = aField.Name &
aField.Label = aLabel
Next
End Sub
It causes an exception. Why doesn't this work? How can in add a Control-Instance to the header?
Same problem is with the tabcontrol in dockingmanager. Guees same problem for all headeredcontentcontrols.
Thanks for your reply,
karle
  • 27093
    Hello Karle,
    I have been looking into your issue and am not quite sure what are you trying to achieve with this snippet. If you want to set your Field’s Label through code all you have to do is :
    aField.Label = aField.Name + " *"
    If you want to alter the visual tree of the Field header you can retemplate its LabelPresenter using the FieldSetting’s LabelPresenterStyle property. You can get the original template form the DefaultStyles folder provided with the product.
    Hope this helps. Please let me know if you require any further assistance on the matter.
    Sincerely,
    Petar Monov
    Developer Support Engineer
    Infragistics Bulgaria
    www.infragistics.com/support
  • 515
    I'm still waiting for this issue to become a support request....
    Can i do something to speed up this process?
