585
Printing XamDataGrid with Bitmaps
I have a XamDataGrid with some fields where I display a status as a BitmapSource via an IValueConverter.
On screen this works well. But when i print my grid all fields show the same image although my converter is called with the right value for each field.
This is my converter:
public object Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
            try
                DB.WFAG.StatusFarben status = (DB.WFAG.StatusFarben)System.Convert.ToInt16(value);
                switch (status)
                    case WFCS.Infrastruktur.DB.WFAG.StatusFarben.Lila:
                        return BitmapSourceFromImage(Properties.Resources.uv_on_16);
                        break;
                    case WFCS.Infrastruktur.DB.WFAG.StatusFarben.Blau:
                        return BitmapSourceFromImage(Properties.Resources.blue_on_16);
                        break;
                    case WFCS.Infrastruktur.DB.WFAG.StatusFarben.Gelb:
                        return BitmapSourceFromImage(Properties.Resources.yellow_on_16);
                        break;
                    case WFCS.Infrastruktur.DB.WFAG.StatusFarben.Gruen:
                        return BitmapSourceFromImage(Properties.Resources.green_on_16);
                        break;
                    case WFCS.Infrastruktur.DB.WFAG.StatusFarben.Grau:
                        return BitmapSourceFromImage(Properties.Resources.white_on_16);
                        break;
                    case WFCS.Infrastruktur.DB.WFAG.StatusFarben.Schwarz:
                        return BitmapSourceFromImage(Properties.Resources.black_off_16);
                        break;
                    case WFCS.Infrastruktur.DB.WFAG.StatusFarben.RotFehler:
                    default:
                        return BitmapSourceFromImage(Properties.Resources.red_on_16);
                        break;
            catch (Exception)
        private static BitmapSource BitmapSourceFromImage(System.Drawing.Image img)
            var memStream = new System.IO.MemoryStream();
            //save the image to memStream as a png
            img.Save(memStream, System.Drawing.Imaging.ImageFormat.Png);
            //gets a decoder from this stream
            var decoder = new PngBitmapDecoder(memStream, BitmapCreateOptions.PreservePixelFormat, BitmapCacheOption.Default);
            return decoder.Frames[0];
And i'm using it like this:
                        <igDP:Field Name="WFKO_StatusFremdfertigung" Label="FAStOK" >
                            <igDP:Field.Settings>
                                <igDP:FieldSettings CellValuePresenterStyle="{StaticResource AGStatusLED}" AllowEdit="False" Width="Auto"/>
                            </igDP:Field.Settings>
                        </igDP:Field>
This is how it looks on screen:
This is how the print looks like:
It seems like the report just uses the first BitmapSource for all fields although the converter returns the right values.
Is there a way to print the right images or is this just a bug?
Bastian
