714
Error when when closing a tab that has XamRadialGauge
I get the following error when a tab is closed which has a XamRadialGauge.
System.ArgumentException: '-25' is not a valid value for property 'Width'.
I've prepared a sample project that reproduces the error but couldn't attach the project as a zip file because of the error I get while adding zip file. Therefore I attached the MainWindow.xaml file with txt extension.
I tried to track down the error and found that it was the RadialGaugeTickMarkGroup causing the problem. But I don't know how to solve it. Apparently I can not give up on tickmarks! So I need an immediate solution to this error.
Can anyone help?
Thanks in advance
