455
Unhandled NullReference Exception causing crash in xamdataGrid
We are seeing that our app crashes with a Null reference exception in Infragistics xamDataGrid. The cause of the exception does not seem to be too evident and seems a random occurance. below is the call stack.
Version of Infragistics under use : 10.2.20102.2045
Error: An unrecoverable error has occurred while running Carbon 2010.10.113.5. The application will now exit.
System.NullReferenceException: Object reference not set to an instance of an object.
at Infragistics.Windows.DataPresenter.DataPresenterBase.ExecuteCommandImpl(ExecuteCommandInfo commandInfo, Boolean raiseEvents)
at Infragistics.Windows.DataPresenter.DataPresenterBase.Infragistics.Windows.Commands.ICommandHost.Execute(ExecuteCommandInfo commandInfo)
at Infragistics.Windows.Commands.Commands`1.OnCommand(Object target, ExecutedRoutedEventArgs args)
at System.Windows.Input.CommandBinding.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
at System.Windows.Input.CommandManager.ExecuteCommandBinding(Object sender, ExecutedRoutedEventArgs e, CommandBinding commandBinding)
at System.Windows.Input.CommandManager.FindCommandBinding(CommandBindingCollection commandBindings, Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
at System.Windows.Input.CommandManager.FindCommandBinding(Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
at System.Windows.Input.CommandManager.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
at System.Windows.UIElement.OnExecutedThunk(Object sender, ExecutedRoutedEventArgs e)
at System.Windows.Input.ExecutedRoutedEventArgs.InvokeEventHandler(Delegate genericHandler, Object target)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)
at System.Windows.Input.RoutedCommand.ExecuteImpl(Object parameter, IInputElement target, Boolean userInitiated)
at System.Windows.Input.RoutedCommand.Execute(Object parameter, IInputElement target)
at Infragistics.Windows.Commands.Commands`1.ProcessKeyboardInput(KeyEventArgs e, ICommandHost commandHost)
at Infragistics.Windows.DataPresenter.DataPresenterCommands.ProcessKeyboardInput(KeyEventArgs e, ICommandHost commandHost)
at Infragistics.Windows.Controls.IGControlBase.OnKeyDown(KeyEventArgs e)
at System.Windows.UIElement.OnKeyDownThunk(Object sender, KeyEventArgs e)
at System.Windows.Input.KeyEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndKeyboardInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawKeyboardActions actions, Int32 scanCode, Boolean isExtendedKey, Boolean isSystemKey, Int32 virtualKey)
at System.Windows.Interop.HwndKeyboardInputProvider.ProcessKeyAction(MSG& msg, Boolean& handled)
at System.Windows.Interop.HwndSource.CriticalTranslateAccelerator(MSG& msg, ModifierKeys modifiers)
at System.Windows.Interop.HwndSource.System.Windows.Interop.IKeyboardInputSink.TranslateAccelerator(MSG& msg, ModifierKeys modifiers)
at System.Windows.Forms.Integration.ElementHost.ProcessCmdKey(Message& msg, Keys keyData)
at System.Windows.Forms.Control.PreProcessMessage(Message& msg)
at System.Windows.Forms.Control.PreProcessControlMessageInternal(Control target, Message& msg)
at System.Windows.Forms.Application.ThreadContext.PreTranslateMessage(MSG& msg)
