I think this is a bug that we can input invalid date. Although the validation can check this value.
I hope we can prevent user from inputting this invalid date.
Let me add one other thought. If you add the following code a message will automatically be displayed for an invalid date.
xamDateTimeEditor1.InvalidValueBehavior = InvalidValueBehavior.DisplayErrorMessage;
I don't know if you noticed that if you drop down the calendar, the date that is actually chosen is today's date when an invalid date is entered.
You can hook to TextChanged event. And here is the event code:
private void XamDateTimeEditor_TextChanged(object sender, RoutedPropertyChangedEventArgs<string> e)
if (dateTime.Mask == "{date}")
if (dateTime.Text == "02/30/")
dateTime.Text = "";
This will prevent you from typing '02/30/____'.
Hope this helps.
Anastas
