490
is it possible to make the xamdatagrid wysiwyg?
I am seeing only a single strip of line in VS when my igxam grid has 3 columns with properties customized.
It will be great if I can somehow see them at design time.
Will Expression Blend with Igx bridge that gap?
thanks
  • 8576
    Hi Vairam -
    The columns are only visible when data is loaded into the XamDataGrid.  This is because the XamDataGrid does not have a fixed band structure (which allows it to support the display of non-homogeneous data) and therefore it must wait until it attempts to load a data record before it can determine the FieldLayout to use (and therefore the columns to display).
    Note: The XamDataGrid does expose a BindToSampleData boolean property that you can use to force sample data to be displayed in the grid.
    Joe
