I have a couple issues regard a xamdatagrid the xaml looks like this:
<Grid> <igDock:XamDockManager Name="xamDockManager"> <igDock:XamDockManager.Panes> <igDock:SplitPane SplitterOrientation="Horizontal" igDock:XamDockManager.InitialLocation="DockedTop" MinHeight="170"> <igDock:SplitPane SplitterOrientation="Vertical"> <igDock:ContentPane Header="Data Entry" HorizontalAlignment="Stretch" igDock:SplitPane.RelativeSize="4,1" MinWidth="712"> <StackPanel Height="Auto" Name="spDataEntry" Width="Auto"> <StackPanel Height="Auto" Name="spHeader" Width="Auto" MinHeight="75" VerticalAlignment="Stretch"> <igDP:XamDataGrid Name="grid1" ClipToBounds="True" SnapsToDevicePixels="False"></igDP:XamDataGrid> </StackPanel> <StackPanel Height="Auto" Name="spDetail" Width="Auto" MinHeight="75" VerticalAlignment="Stretch"> <igDP:XamDataGrid Name="grid2" ClipToBounds="True" SnapsToDevicePixels="False"></igDP:XamDataGrid> </StackPanel> </StackPanel> </igDock:ContentPane> <!--Vendor Info--> <igDock:ContentPane Header="Vendor Info" HorizontalAlignment="Stretch" igDock:SplitPane.RelativeSize="1,4"> <StackPanel Height="Auto" Name="spVendorInfo" Width="Auto" > <StackPanel Name="spInfoBox" Width="Auto" MinHeight="60" > <TextBox Name="txtVendorInfo" Width="Auto" Height="Auto" MinHeight="60" TextWrapping="Wrap" AcceptsReturn="True" AcceptsTab="True" HorizontalScrollBarVisibility="Auto" IsReadOnly="True" VerticalScrollBarVisibility="Auto" /> </StackPanel> <StackPanel Name="spRecvTicket" Width="Auto" MinHeight="20" > <CheckBox Name="chkReceivingTicket" Width="Auto" Height="16" Content="Receiving Ticket Attached" VerticalContentAlignment="Center" /> </StackPanel> <StackPanel Name="spInfoGrid" Width="Auto" Height="Auto" > <igDP:XamDataGrid x:Name="grdInfo" Width="Auto" Height="Auto" MinHeight="70"> <igDP:XamDataGrid.FieldLayoutSettings> <igDP:FieldLayoutSettings AutoGenerateFields="True" /> </igDP:XamDataGrid.FieldLayoutSettings> </igDP:XamDataGrid> </StackPanel> </StackPanel> </igDock:ContentPane> </igDock:SplitPane> </igDock:SplitPane> </igDock:XamDockManager.Panes> </igDock:XamDockManager> </Grid>
The grid is bound to a DataRowCollection in code. Here is the code
public Window1() { InitializeComponent(); } private void Window_Loaded( object sender , RoutedEventArgs e ) { this.grid1.FieldLayoutSettings.AutoGenerateFields = true; this.grid1.FieldLayoutSettings.AllowAddNew = true; this.grid1.FieldLayoutSettings.AddNewRecordLocation = Infragistics.Windows.DataPresenter.AddNewRecordLocation.OnBottom; this.grid1.FieldLayoutSettings.AllowFieldMoving = Infragistics.Windows.DataPresenter.AllowFieldMoving.No; this.grid1.FieldLayoutSettings.AutoArrangeCells = Infragistics.Windows.DataPresenter.AutoArrangeCells.LeftToRight; this.grid1.FieldSettings.AllowFixing = Infragistics.Windows.DataPresenter.AllowFieldFixing.No; this.grid1.FieldSettings.AllowGroupBy = false; this.grid1.FieldSettings.AllowSummaries = false; this.grid1.FieldSettings.AllowHiding = AllowFieldHiding.ViaFieldChooserOnly; DataTable invoices = new DataTable(); invoices.Columns.Add("invoiceId"); invoices.Columns.Add("vendor"); invoices.Columns.Add("date"); invoices.Columns["date"].DataType = typeof(DateTime); invoices.Rows.Add(new object[] { 1 , "abc123" , DateTime.Now }); invoices.Rows.Add(new object[] { 2 , "blah blah" , DateTime.Now }); this.grid1.DataSource = invoices.Rows; Style s = new Style(typeof(Infragistics.Windows.Editors.XamDateTimeEditor)); Setter set = new Setter(Infragistics.Windows.Editors.XamDateTimeEditor.FormatProperty , "MM-dd-yyyy"); s.Setters.Add(set); set = new Setter(Infragistics.Windows.Editors.XamDateTimeEditor.MaskProperty , "mm-dd-yyyy"); s.Setters.Add(set); this.grid1.FieldLayouts[0].Fields["date"].Settings.EditorStyle = s; s = new Style(typeof(Infragistics.Windows.Editors.XamMaskedEditor)); set = new Setter(Infragistics.Windows.Editors.XamMaskedEditor.MaskProperty , string.Format("{0}" , "".PadLeft(12 , '&'))); s.Setters.Add(set); this.grid1.FieldLayouts[0].Fields["vendor"].Settings.EditorStyle = s; this.grid1.EditModeEnding += new EventHandler<Infragistics.Windows.DataPresenter.Events.EditModeEndingEventArgs>(grid1_EditModeEnding); } void grid1_EditModeEnding( object sender , Infragistics.Windows.DataPresenter.Events.EditModeEndingEventArgs e ) { }
The problem occurs when im editing a cell and then i leave that cell by clicking one of the other dock panels. When I try to re-enter the cell that is in edit mode i cannot and the cell seems to be frozen in edit mode. I have to click on another cell and then reenter the original cell to get back into editing the original cell. Furthermore, in some cases the cell freezes in edit mode and i cannot get back into the cell or any other cell. In this case, I have to close and reload the form.
Any suggestions?
Thanks again.
cool!!, that worked
Hello again,
You can see how to show a load animation while the Data is being retrieved:
http://ko.infragistics.com/community/forums/t/72122.aspx
Hi Stefan,
Thanks for reply, I had some logic behind xamdatagrid's parent control click, which was calling on xamDataGrid’s cell click, I am good with that now.
Can you answer me my second question, is there Dataload event complete event in xamdataGrid, and if not is there a way to show spinner till dataload is complete.
Hello Yogi,
Thank you for your post I have been looking into your post and I created a sample project for you following your scenario and everything seems to work ok on my side. If the sample doesn’t satisfies all your needs feel free to modify it, so it reproduces your behavior and send it back to me for further investigation.
