155
XamPivotGrid exception
I got below exception when I tried to use a XamPivotGrid in my windows app. Version: 2010.3. OS: Windows XP. PLease let me know if you have any adea. Thanks, Joseph
System.NullReferenceException: Object reference not set to an instance of an object.
   at Infragistics.Controls.Grids.PivotGridCellBase.get_ResolveStyle()
   at Infragistics.Controls.Grids.PivotCell.get_ResolveStyle()
   at Infragistics.Controls.Grids.PivotGridCellBase.ApplyStyle()
   at Infragistics.Controls.Grids.PivotGridCellBase.OnElementAttached(PivotGridCellControlBase element)
   at Infragistics.RecyclingContainer`1.Infragistics.ISupportRecycling.OnElementAttached(FrameworkElement elem)
   at Infragistics.RecyclingManager.PanelInfo.AttachElement(ISupportRecycling obj)
   at Infragistics.Controls.Grids.PivotPanelBase.RenderCell(PivotGridCellBase cell, Double availableWidth, Double availableHeight)
   at Infragistics.Controls.Grids.PivotDataRowsPanel.RenderEmptyCell()
   at Infragistics.Controls.Grids.PivotDataRowsPanel.MeasureOverride(Size availableSize)
   at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
   at System.Windows.UIElement.Measure(Size availableSize)
   at Infragistics.Controls.Grids.PivotGridPanel.MeasureInternal(Size availableSize)
   at Infragistics.Controls.Grids.PivotGridPanel.MeasureOverride(Size availableSize)
   at System.Windows.Controls.Grid.MeasureCell(Int32 cell, Boolean forceInfinityV)
   at System.Windows.Controls.Grid.MeasureCellsGroup(Int32 cellsHead, Size referenceSize, Boolean ignoreDesiredSizeU, Boolean forceInfinityV)
   at System.Windows.Controls.Grid.MeasureOverride(Size constraint)
   at System.Windows.Controls.Border.MeasureOverride(Size constraint)
   at System.Windows.Controls.Control.MeasureOverride(Size constraint)
   at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint)
   at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint)
   at System.Windows.Controls.DockPanel.MeasureOverride(Size constraint)
   at System.Windows.Documents.AdornerDecorator.MeasureOverride(Size constraint)
   at System.Windows.Interop.HwndSource.SetLayoutSize()
   at System.Windows.Interop.HwndSource.set_RootVisualInternal(Visual value)
   at System.Windows.Interop.HwndSource.set_RootVisual(Visual value)
   at System.Windows.Forms.Integration.ElementHost.OnHandleCreated(EventArgs e)
   at System.Windows.Forms.Control.WmCreate(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Integration.ElementHost.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
  • 138253
    Hello Joseph,
    It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking through your post and it seems like I am missing something and I wasn’t able to reproduce your behavior, so if this is still an issue could you please provide me with an isolate sample project where this exception occurs, so I can investigate it further for you.
