235
Cell clipping in XamDatagrid
I have the requirement to display some Icon in the cell that spans over other cells - see picture
(removed)
It worked well before columns freezing was turned on for two first columns on the grid via the following code
var field = new UnboundField()
       Name = column.FieldName,
       Label = column.Title,
       Width = new FieldLength(1, FieldLengthUnitType.Auto)
       field.Settings.AllowFixing = AllowFieldFixing.Near;
       field.FixedLocation = FixedFieldLocation.FixedToNearEdge;
 After this that Icon with 'A' is being clipped - see below
 (removed)
I've tried to fix it by overriding styles but it didn't solve the issue.
<Style TargetType="{x:Type igDP:CellValuePresenter}">
       <Setter Property="Clip" Value="{x:Null}"/>
</Style>
<Style TargetType="{x:Type igDP: DataRecordCellArea}">
</Style>
Could you please advise how to fix the issue so that Icon won't be clipped with "freeze columns' turned on?
