95
HierarchicalDataTemplate for xamDataTree
Hello, i'm a wpf professional but new to infragistics. So i have a question about templating the xamdatatreee but i found no answer in the documention.
I understand, that you layout/template the xamdatatree with your fieldlayout-mechanism. But xamdatatree understand <DataTemplate>s too. So i try
<ig:XamDataTree
  ItemsSource="{Binding RootItemListe}"
  ItemTemplate="{StaticResource local_TreeViewItemTemplate}"
and as ItemTemplate i'm using is:
<HierarchicalDataTemplate ItemsSource="{Binding Children}" x:Key="local_TreeViewItemTemplate">
  <TextBlock Text="{Binding MyProperty}" />
</HierarchicalDataTemplate>
That works find but you interpret this HierarchicalDataTemplate only as simple <DataTemplate> (it's the baseclass).
Is it possible that you recognice it as <HierarchicalDataTemplate> with the 'ItemsSource'-Property to generate the Childnodes automaticly? That would be the "normal" way of WPF for me....
Thank you for support,
Sascha
  • 5595
    Verified Answer
    DataTree does not support HierarchicalDataTemplate, it has different mechanism to displaying building hierarchical data:
    1. Using Global Layout definition:
    <ig:XamDataTree.GlobalNodeLayouts>
             <ig:NodeLayout Key="MyCollectionProperty"
                              DisplayMemberPath="MyProperty"
                              TargetTypeName="MyType"/>
    </ig:XamDataTree.GlobalNodeLayouts>
    2. Using Nested Layout definition:
    <ig:XamDataTree.NodeLayouts>
    <ig:NodeLayout Key=" MyCollectionProperty"
    TargetTypeName="MyType">
    <ig:NodeLayout.NodeLayouts>
    </ig:NodeLayout>
    </ig:NodeLayout.NodeLayouts>
    </ig:NodeLayout>
    </ig:XamDataTree.NodeLayouts>
    Where:
    • MyType is the type of the objects you would like to see at the corresponding level
    • MyProperty is the property you would like to bind treeitem's header to
    • MyCollectionProperty - the property that contains the data items for the corresponding level
    HTH,
