220
XamComboEditor Binding fails
below is the code of one of the unbound column i've used in xamdatagrid.
this column has xamcomboeditor that suppose to be bounded to the property of the DataItem which is of type Enum.
to show the user proper text I've used EnumToString converter to convert enum to Text. this class returns Dictionary<string,Enum> which is later bound to the xamcomboeditor.
<igDP:UnboundField BindingPath="SelectedSubmitMethod" Label="Submit Method" Width="50" Column="2"  Row="1"  >
                        <igDP:UnboundField.Settings>
                                <igDP:FieldSettings  EditorType="{x:Type igEditors:XamComboEditor}" LabelWidth="0" AutoSizeScope="RecordsInView" DataValueChangedNotificationsActive="True" >
                                <igDP:FieldSettings.EditorStyle  >
                                        <Style TargetType="{x:Type igEditors:XamComboEditor}">
                                            <!--<Setter  Property="ItemsSource" Value="{Binding Path=DataItem.AvailableSubmitMethods, Converter={StaticResource ResourceKey=EnumToStringConverter}, UpdateSourceTrigger=PropertyChanged, NotifyOnValidationError=True}"   />-->
                                            <Setter Property="ItemsSource">
                                                <Setter.Value>
                                                    <Binding Path="DataItem.SelectedSubmitMethod" Converter="{StaticResource ResourceKey=EnumToStringConverter}" UpdateSourceTrigger="PropertyChanged"  FallbackValue="Print" NotifyOnValidationError="True" >
                                               </Binding>
                                                </Setter.Value>
                                            </Setter>
                                            <Setter Property="DisplayMemberPath" Value="Key"/>
                                            <Setter Property="ValuePath" Value="Value"/>
                                        </Style>
                                    </igDP:FieldSettings.EditorStyle>
                            </igDP:FieldSettings>
                        </igDP:UnboundField.Settings>
                    </igDP:UnboundField>
when i used
it works fine, but when i used
                                                <Setter.Value>
                                               </Binding>
                                                </Setter.Value>
                                            </Setter>
it failed with below errors:
System.Windows.Data Error: 40 : BindingExpression path error: 'Value' property not found on 'object' ''Char' (HashCode=7602292)'. BindingExpression:Path=Value; DataItem='Char' (HashCode=7602292); target element is 'ComboBox' (Name=''); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 40 : BindingExpression path error: 'Key' property not found on 'object' ''Char' (HashCode=7602292)'. BindingExpression:Path=Key; DataItem='Char' (HashCode=7602292); target element is 'ComboBox' (Name=''); target property is 'NoTarget' (type 'Object')
Can someone please point out what am i doing wrong here?
