95
Header caption cropped by sort-indicator
Please have a look at 2nd column on my attached screenshot. The title of den "Department"-column is cropped if i use "Aero"-theme, what is defualt.
If i use an other theme, than it works fine. I guess it is the sort-indicator an its visibility is Hidden and not Collapsed.
  • 138253
    It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. So I have been looking through you post and I made a research and it turns out that this issue doesn’t occur in version 11.1 or in the last service release of version 10.3. So I can suggest you either upgrade to the latest service release of 10.3 or get our 11.1 version.
    Feel free to write me if you have any other questions.
