350
How to create a chart and set properties by only VB.NET code
I'd like to create a chart,then set legend text and format  AxisY(datetime) by only VB.NET codes(not xaml).How to?
Best regards.
  • 30692
    Here's an example of how to create and customize a chart manually. If you aren't using VS2010 you may need to add some underscores here and there as line continuations.
    Imports Infragistics.Windows.Chart
    Class MainWindow
        Public Sub New()
            InitializeComponent()
            Dim chart As New XamChart
            Dim series As New Series With {
                .ChartType = ChartType.Line,
                .Label = "Sample"}
            series.DataPoints.Add(
                New DataPoint() With {.Label = "A", .Value = 1})
                New DataPoint() With {.Label = "B", .Value = 2})
                New DataPoint() With {.Label = "C", .Value = 3})
                New DataPoint() With {.Label = "D", .Value = 4})
            chart.Series.Add(series)
            Dim yAxis As New Axis With {
                .AxisType = AxisType.PrimaryY,
                .StrokeThickness = 2,
                .Stroke = New SolidColorBrush(Colors.Red)}
            chart.Axes.Add(yAxis)
            grid.Children.Add(chart)
        End Sub
    End Class
    Hope this helps!
    -Graham
