I have xamDataGrid that contains several expanded grouping records. I try to navigate between records using Page Up/Page Down keys. So in my case I selext first record in grid, then I press Page Down and last row on screen is select, then I press Page Down in second time and see that second page is shown but selected row is not last in view (see last screenshot below). But I expect that last record on second page should be select. Could you suggest how to fix it? I attached sample project to this post.
HI,
This issue should be resolved with the latest service release.
Sincerely Matt Developer Support Engineer
It reprodicble on Win XP and Win 7. To reproduce it I just run attached sample, select first data record and press PageDown key two times.
I was not able to reproduce this issue. What operating system are you running on. Sincerely. Matt Developer Support Engineer
