I am working on Infragistics Datagrid (V 10.2), I have a field that contains a TextBox and a Lookup Button that popsup a window with a table of 3 other columns on button click event. I am good till this.
But my problem here is, when i select a row in popup window, all the vales in the three fields of the popup window should be binded to the textbox beside the lookup button and other two fields in the infragistics grid.
These are the styles I wrote for Button and TextBox:
<Style TargetType="{x:Type igDP:CellValuePresenter}" x:Key ="SearchButtonFieldStyle">
<Setter Property="ContentTemplate">
<Setter.Value>
<DataTemplate>
<DockPanel>
<igRibbon:ButtonTool Height="22" DockPanel.Dock="Right" Name="btnGridLookUp" SmallImage="/Images/Lookup.png" ToolTip="LookUp" Width="27" Click="btnGridLookUp_Click">
<igRibbon:ButtonTool.BitmapEffect>
<BitmapEffectGroup>
<DropShadowBitmapEffect />
</BitmapEffectGroup>
</igRibbon:ButtonTool.BitmapEffect>
</igRibbon:ButtonTool>
<ContentPresenter Content="{TemplateBinding Content}"/>
</DockPanel>
</DataTemplate>
</Setter.Value>
</Setter>
</Style>
<Style TargetType="{x:Type igEditors:XamTextEditor}" x:Key="TextStyle">
<Setter Property="Background" Value="Transparent" />
This is how I binded them to Grid:
<igDP:Field Name="Col3" Label="TestSample" Width="80">
<igDP:Field.Settings>
<igDP:FieldSettings CellValuePresenterStyle="{StaticResource SearchButtonFieldStyle}" EditorStyle="{StaticResource TextStyle}"/>
</igDP:Field.Settings>
</igDP:Field>
Here I am not sure of how to access/bind a value to the textbox beside the button.
Please advise.
Rakesh
Hi Rakesh,
I’m just following up on this forum post.
Is there anything further that I can help you with regarding this question?
If so, please feel free to contact me.
I used this code in the button click event to search the visual tree looking for the cellValuePresenter. Then I can get to the record and use all of the cell values.
I think this is what you need to value the pop up window.
private void btnGridLookUp_Click(object sender, RoutedEventArgs e){ Debug.WriteLine("btnGridLookUp_Click");
ButtonTool bt = sender as ButtonTool;
DependencyObject dp = VisualTreeHelper.GetParent(bt); if (dp.GetType() != typeof(CellValuePresenter)) { while (dp != null && dp.GetType() != typeof(CellValuePresenter)) { dp = VisualTreeHelper.GetParent(dp); } } if (dp != null ) { CellValuePresenter cvp = dp as CellValuePresenter; DataRecord dr = cvp.Record as DataRecord;
for (int i = 0; i < dr.Cells.Count - 1; i++) { Debug.WriteLine("Cell" + i.ToString() + " " + dr.Cells[i].Value.ToString()); } }}
