Hi all,
1. How to focus on a cell in the filter row on load?2. In a grid, I have two columns in editable mode. Tabbing should take place in these two fields. Tab 1 takes to the first editable field in first row, Tab 2 takes to the next editable column and Tab 3 should take to the first editable field in the second row.
Hello Suhas,
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post and I modified the sample I have attached before, so now it has the functionality you want.
I would like to have some suggestions for focusing a particular cell on creating a new row on tab out event .May be a pseudocode.
I have a problem where I have some 8 cells in a row, but i need to maintain the tab order for the cells 2,3 4,5 and after the tabout of the 5th cell,I need to create a new row. After creating the new row I need to focus on the 2nd cell of the new row and not the first cell.
Thank you
Suhas
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking through your post and I created a sample project for you with the functionalities you want.
