1025
Unable to get RecordPresenter from Record
I have the following code that always seems to return null. What am I doing wrong here? I am trying to attach a ContextMenu to the Record. Unless someone has an idea how I can show a ContextMenu that queues off of the selected Record. ie. Delete this selected row.
void theDataGrid_InitializeRecord(object sender, InitializeRecordEventArgs e)
if (e.Record != null)
DataRecordPresenter drp = DataRecordPresenter.FromRecord(e.Record) as DataRecordPresenter;
Rod
  • 8576
    Hi Rod -
    This is a timing issue - when InitializeRecord is called we are creating the DataRecord 'wrappers' for each of the items in the data source, but we have not yet created the associated DataRecordPresenters.  You would need to either wait until the after DataRecordPresenter has been created (i.e., after the DataRecord has been displayed) or do this asynchronously like so:
    this.Dispatcher.BeginInvoke(DispatcherPriority.Loaded, new RecordMethod(this.GetRecordPresenterForRecord), e.Record);
    delegate void RecordMethod(Record rcd);
    private void GetRecordPresenterForRecord(Record rcd)
    DataRecordPresenter drp = DataRecordPresenter.FromRecord(rcd) as DataRecordPresenter;
    Joe
    "rodyager" wrote in message news:23817@forums.infragistics.com...
    Rod
    http://forums.infragistics.com/forums/p/5266/23817.aspx#23817
