490
Using the mouse to move datapoints
Hey guys,
I was working off an example I found on these forums to allow users to interact with the chart using the mouse.  I capture the usual mouse events and as the mouse moves, I update the datapoint's value (I'm using a 2D line chart).
However, there is a problem I am running into.  As I drag a value, the y-axis value might change (sinve the y-axis has AutoRange set to true).  The problem is when the range of the y-axis changes, the datapoint appears in  a different position on the screen, and is no longer under the mouse. It is easy to see this.  Just slowly drag a datapoint.  It will be under the mouse until the range of the y-axis is changed.  Then the datapoint is "moved" and the next mouse move causes it to jump ahead.  This causes erratic movements when using the mouse to change a value.
Is there a way to have the datapoints move smoothly along with the mouse when AutoRange is set to true?
