645
Ensuring a particular data point is visible
I show scatter series on my xamDataChart and some of these series can have a very large number of points.  I know that I can set the MaximumMarkers like so:
myScatterSeries.MaximumMarkers = 1000; // or whatever
and that seems to work well enough when I don't have > 1000 points in the series.  But prior to runtime, it's anybody's guess how many points will be there.
So what happens is that point's 1, 2, 5, 7 might be visible but 3, 4 and 6 are not.  I'm generally OK with that and typically the user would zoom into a region of the chart and then 3,4 and 6 are visible.
Externally, a particular point can have attributes (marked as "of interest", for instance) and those points stand out by having their rendertransform 2x the height to make them bigger.
But if that point isn't currently displayed (it's point 3, 4, or 6 in my example), the user misses the fact that this point is there since it isn't visible.
Is there a way to ensure that any specific data point is visible?
Matt
  • 7305
    Suggested Answer
    I am following up to see if you have any questions regarding implementeing Graham's suggestion.
    Thank you,
    Sam
  • 30692
    Verified Answer
    One way would be to put the points that are "of interest" into a seperate series which you also set the Maximum markers to be high. This series can share the same x and y axis with the other series. As long as the number of "of interest" points doesnt climb above max markers then all of them should be displayed.
    There are various other strategies you could use if this isn't an acceptable solution for whatever reason. Let me know.
    Hope this helps!
    -Graham
