So I want to be able to toggle the x and y axis on and off.
It seems that toggling them to visible to false doesn't expand the chart area if you've set the margin manually. This seems like a massive oversight given that WPF provides visibility with Visbile, Hidden and Collapsed. Why the xamChart doesn't use this I have no idea.
Then when I try to setup a data trigger to adjust the margin in the standard WPF way it doesn't seem to work at all.
<igCA:XamChart DockPanel.Dock="Bottom" HorizontalAlignment="Stretch" Name="MainChart" VerticalAlignment="Stretch" VerticalContentAlignment="Stretch" HorizontalContentAlignment="Stretch"
Style="{StaticResource ResourceKey=XamChartStyle1}">
<igCA:XamChart.Scene>
<igCA:Scene Style="{StaticResource xamSceneStyle}" >
<igCA:Scene.GridArea>
<igCA:GridArea x:Name="MainGridArea" MarginType="Percent" Margin="7,3,3,7">
<igCA:GridArea.Style>
<Style TargetType="{x:Type igCA:GridArea}" >
<Style.Triggers>
<DataTrigger Binding="{Binding Path=LineChartWindow.AxisProp.ShowXAxis}" Value="True" >
<Setter Property="Margin" >
<Setter.Value>
<Thickness Bottom="3" />
</Setter.Value>
</Setter>
</DataTrigger>
</Style.Triggers>
</Style>
</igCA:GridArea.Style>
</igCA:GridArea>
</igCA:Scene.GridArea>
</igCA:Scene>
</igCA:XamChart.Scene>
I haven’t heard back from you. I was wondering if you had any questions.
If so, please feel free to contact me.
What I noticed is that your style is setting the MarginType in the Scene’s GridArea in your code.
Not having all of your code I set up my style to react to a checkbox on my form and applied that style to the scene. With my style I was able to reset the MarginType and Margin based on the state of the checkbox.
<igCA:XamChart.Scene >
<igCA:Scene Background="Beige" BorderBrush="Red" BorderThickness="2" Style="{StaticResource percentSceneStyle}">
This was the style I created.
<Style TargetType="{x:Type igCA:Scene}" x:Key="percentSceneStyle" >
<DataTrigger Binding="{Binding ElementName=cbIsPercentScene, Path=IsChecked}" Value="True">
<Thickness Bottom="10" Top="10" />
<Setter Property=" MarginType" Value="Percent"/>
<DataTrigger Binding="{Binding ElementName=cbIsPercentScene, Path=IsChecked}" Value="False">
<Setter Property=" MarginType" Value="Auto"/>
I would also eliminate the dockpanel that your scene is embedded in. The MarginType and Margin cause the scene to reposition itself within the chart’s client area.
There is a description here of the impact of those properties.
http://help.infragistics.com/NetAdvantage/WPFDV/2011.1/CLR4.0/?page=xamChart_Working_with_the_Chart_Scene.html
