250
Ability to Expand All/Collapse All in XamDataGrid with buttons in HeaderPrefixArea
I have hierarchical xamDataGrid (3 layers) in which I place a +/- button in the HeaderPrefixArea which we would like to expand and collapse upon the +/- button click. Looked at the post (http://forums.infragistics.com/forums/p/37606/218282.aspx) and learnt that there is known issue here. Want to know if that is fixed in release 2010.2. If not, is there any work around for that? I tried the workaround solution given in the above posting but it is not working as desired.
Below is the code:
<Style TargetType="{x:Type igDP:HeaderPrefixArea}" >
    <Setter Property="Template">
        <Setter.Value>
            <ControlTemplate TargetType="{x:Type igDP:HeaderPrefixArea}">
                <StackPanel Orientation="Horizontal" HorizontalAlignment="Left" VerticalAlignment="Stretch">
                    <Button Content="+" HorizontalAlignment="Left"
                            vm:RecordsExpandAllExtension.IsExpandedAll="{Binding RelativeSource={RelativeSource AncestorType={x:Type igDP:XamDataGrid}}, Path=DataContext.IsExpandAllClicked, UpdateSourceTrigger=PropertyChanged, Mode=TwoWay}"
                            Command="{Binding RelativeSource={RelativeSource AncestorType={x:Type igDP:XamDataGrid}}, Path=DataContext.ExpandAllCommand}"
                            Width="15"/>
                    <Button Content="-" HorizontalAlignment="Left"
                            vm:RecordsExpandAllExtension.IsCollapsedAll="{Binding RelativeSource={RelativeSource AncestorType={x:Type igDP:XamDataGrid}}, Path=DataContext.IsCollapseAllClicked, UpdateSourceTrigger=PropertyChanged, Mode=TwoWay}"
                            Command="{Binding RelativeSource={RelativeSource AncestorType={x:Type igDP:XamDataGrid}}, Path=DataContext.CollapseAllCommand}"
                            Width="15"/>
                </StackPanel>
                </ControlTemplate>
        </Setter.Value>
    </Setter>
</Style>
private bool _isExpandAllClicked = false;
public bool IsExpandAllClicked
    get { return _isExpandAllClicked; }
    set
        if (_isExpandAllClicked != value)
            _isExpandAllClicked = value;
            this.RaisePropertyChanged("IsExpandAllClicked");
private bool _isCollapseAllClicked = false;
public bool IsCollapseAllClicked
    get { return _isCollapseAllClicked; }
    set
        if (_isCollapseAllClicked != value)
            _isCollapseAllClicked = value;
            this.RaisePropertyChanged("IsCollapseAllClicked");
protected void XdgOnInitializeRecord(InitializeRecordEventArgs e)
    if (IsExpandAllClicked)
        e.Record.IsExpanded = true;
    else
        e.Record.IsExpanded = false;
public class RecordsExpandAllExtension
    public static bool GetIsExpandedAll(UIElement obj)
        using (Tracing.Source.FunctionScope())
            return ExceptionHandling.Policy.Process(() =>
                return (bool)obj.GetValue(IsExpandedAllProperty);
    public static void SetIsExpandedAll(UIElement obj, bool value)
                obj.SetValue(IsExpandedAllProperty, value);
    public static bool GetIsCollapsedAll(UIElement obj)
                return (bool)obj.GetValue(IsCollapsedAllProperty);
    public static void SetIsCollapsedAll(UIElement obj, bool value)
                obj.SetValue(IsCollapsedAllProperty, value);
    public static readonly DependencyProperty IsExpandedAllProperty =
    DependencyProperty.RegisterAttached(
    "IsExpandedAll",
    typeof(bool),
    typeof(RecordsExpandAllExtension),
    new UIPropertyMetadata(false, OnIsExpandedChanged));
    public static readonly DependencyProperty IsCollapsedAllProperty =
    "IsCollapsedAll",
    typeof(bool),
    new UIPropertyMetadata(false, OnIsCollapsedChanged));
    public static void OnIsExpandedChanged(DependencyObject depObj, DependencyPropertyChangedEventArgs e)
                if (e.NewValue is bool)
                    if ((bool)e.NewValue)
                        XamDataGrid grid = Utilities.GetAncestorFromType(depObj, typeof(XamDataGrid), true) as XamDataGrid;
                        if (grid != null)
                            foreach (DataRecord dr in grid.Records)
                                if (dr.IsExpanded == false)
                                    dr.IsExpanded = true;
    public static void OnIsCollapsedChanged(DependencyObject depObj, DependencyPropertyChangedEventArgs e)
                        if (grid != null)
                                if (dr.IsExpanded == true)
                                    dr.IsExpanded = false;
