We need to give our users the ability to select a row and move it up/down by clicking some buttons. The rows do get moved by modifying the underlying IBindingList.
The problem is that selection doesn't work quite well. It gets lost after clicking - for instance - the "Move Up" button a couple of time.
In order to keep track of the selection, I'm using the approach explained here - http://community.infragistics.com/forums/p/27581/269608.aspx
But even though the properties are correctly setup, the behavior is not consistent.
Any suggestions?
Many thanks.
-Alberto.
Hello Kamlendra,
I found this post duplicate to this one:
http://ko.infragistics.com/community/forums/p/85134/425066.aspx#425066
which is already discussed.
i have to give the same functionality. Moving row up/down by selecting and dragging the row. can you please suggest some sample.
(i have to move rows i don't have to move them up and down by dragging only.don't need a seperate button)
Tahnks,
Kamlendra
Yeah, it was just a minor styling bug. Thanks for following up.
Regards.
Hello Alberto,
Sincerely,
Petar Monov
Developer Support Engineer
Infragistics Bulgaria
www.infragistics.com/support
I have been reading through your description and was wondering if you could please provide a little more details about how exactly do you want to move the records and what have you done so far to implement this. Also some descriptive screenshots or a sample project would really help illustrate your scenario and desired behavior.
