85
XamChart Crosshairs.GraphY
Hi, i need your help!!!!
Currently i´m developing a user control, which consists of a XamChart, where I get the value of Crosshairs.GraphY, but always returns 0.0, when the XamWebChart on Silverlight if you return the value to be, exists a problem with this property?
This is to do a Drag & Drop column, i'm repeat on Silverlight  works right, but on WPF not
Sample of my code:
XAML
<igCA:XamChart HorizontalAlignment="Stretch" Name="xamWebChart1" VerticalAlignment="Stretch" Width="Auto" MouseMove="xamWebChart1_MouseMove" MouseDown="XamChart1_MouseDown" MouseUp="xamChart1_MouseUp" />
xaml.cs
private
private void xamChart1_MouseUp(object sender, MouseButtonEventArgs e)
ShapeToNull();
if (_tmpStock == null)
return;
private void ShapeToNull()
if (_shape != null)
_shape =
null;
TextBlockColumnValue.Opacity = 0;
Cursor =
null;
Thanks and if you need more info about the case, let me know.
Regards.
private void XamChart1_MouseDown(object sender, MouseButtonEventArgs e)
_shape =
this.xamWebChart1.HitTest(e);
Cursor =
Cursors.SizeNS;
var webChart = (XamChart)sender;
var index = 0;
foreach (var serie in webChart.Series)
DataPoint dp = _shape.SelectedObject as DataPoint;
if (dp != null)
/*string _nameof = dp.Name;
double _valueof = dp.Value;*/
index = serie.DataPoints.IndexOf(dp);
if
(index > -1)
_tmpStock = _stockViewModelFiltered.SumarizedStocks[index];
var names = serie.DataMapping.Split(new char[] { ';', '=', ' ' }, StringSplitOptions
.RemoveEmptyEntries);
_tmpColumnName = names[3];
break
private
void xamWebChart1_MouseMove(object sender, MouseEventArgs e)
if (_shape != null)
var xamWebChart = (XamChart)sender;
var graphY = xamWebChart.Crosshairs.GraphY; <-- Here return 0.0
dp.Value = graphY;
TextBlockColumnValue.Text = ((
int
)graphY).ToString();
TextBlockColumnValueTranslateTransform.X = e.GetPosition(
this
).X - 40;
TextBlockColumnValueTranslateTransform.Y = e.GetPosition(
this
).Y;
TextBlockColumnValue.Opacity = _opacity;
else
HitTestArgs _shape;
  • 17605
    Have you tried enabling the Crosshairs:
    <igCA:XamChart>
                <igCA:XamChart.Crosshairs>
                    <igCA:Crosshairs Enabled="True" />
                </igCA:XamChart.Crosshairs>
