hi,
I am trying to write a mask which allows me to enter any characters including all the special characters and maximum 200 characters. I am setting mask like - Mask="{}{char:200:0-9a-zA-Z\/@-_.#$%^ }".It does not allow me to set the text which contains chars like / and \.Can anyone please suggest how to set the mask for this requirement.
Regards,Sachin
Hello Sachin,
Were you able to resolve your issue?
Valerie
I tested the mask you provided and I was able to enter / and \ characters in a xamMaskedEditor.
I have attached the sample project I used to test this. Please test this project on your PC; whether or not it works correctly may help indicate the nature of this problem.
If the project does not work correctly, this indicates either a problem possibly specific to your environment, or a difference in the DLL versions we are using. My test was performed using version 10.3.20103.1003 in NetAdvantage for 2010 Volume 3.
If the project does show the product feature working correctly, this indicates a possible problem in the code of your application. It will help if you can provide a small, isolated sample application that demonstrates the behavior you are seeing.
Or, if this sample project is not an accurate demonstration of what you're trying to do, please feel free to modify it and send it back, or send a small sample project of your own if you have one.
Please let me know if I can provide any further assistance.
