200
Problem with some filters's combinations
I'm using a filter called Indicator who takes two possible values: Gasto or Costo.
When I use this filter in combination with an another and then I select the two possible values of the filter Indicator, the grid shows correctly the results for both values (first image). But when I select one of the possible values (Costo), the grid doesn't recalculate the data (doesn't refresh, second image). Then I select the second possible value of the filter (Gasto) and the grid shows the correct data (recalculate the result) for that value (third image).
How can I resolve this problem? Is there a basic or obligatory combination of filters that I must use to show and filter correctly the results in the grid?
