215
Interaction.Triggers + xamContextMenu
I have a the following code (Code #1) attached to a XamDataGrid:
<ig:ContextMenuManager>
   <ig:ContextMenuManager.ContextMenu>
      <ig:XamContextMenu>
          <ig:XamMenuItem Header="Edit">
              <i:Interaction.Triggers>
                  <i:EventTrigger EventName="Click">
                      <i:InvokeCommandAction Command="{Binding Path=MyCommand}" />
                   </i:EventTrigger>
              </i:Interaction.Triggers>
           </ig:XamMenuItem>
       </ig:XamContextMenu>
   </ig:ContextMenuManager.ContextMenu>
</ig:ContextMenuManager>
where
xmlns:ig="http://schemas.infragistics.com/xaml" xmlns:i="clr-namespace:System.Windows.Interactivity;assembly=System.Windows.Interactivity"
The command does not work as intended, nothing is being shown.
The following code (Code #2) works as intended:
<Button Content="Save" Height="20"> <i:Interaction.Triggers>     <i:EventTrigger EventName="Click">         <i:InvokeCommandAction Command="{Binding Path=MyCommand}"/>         </i:EventTrigger>     </i:Interaction.Triggers> </Button>
When I change MyCommand in Code #2 to MyCommand2 (which doesn't exist) it tries to find the property MyCommand2 on the DataContext
MyCommand does actually exist on the DataContext (as shown on Code #2)
The command actually is
private ICommand _myCommand;
public ICommand MyCommand
{ get     {     return _myCommand ?? (_myCommand = new RelayCommand(param => MessageBox.Show("TEST!")));     }             }
I'm using the MVVM architecture.
Why doesn't the Code #1 work? Any ideas?
Thank you!
Parents Reply Children
No Data
