I need to be able to support a grid which at design time will not have a set number of columns. For example, the app will run, get some data from the server and create some objects. Depending on the response from the server, I may have a different number of objects each time I run the app.
What do I need to do to be able to have my grid show the right number of columns and bind them to the right objects? I am guessing this will need to be done in code since it cannot be done in XAML.
Can someone provide a simple exampe of this functionality please?
Thanks.
You have to set AutoGenerateFields property to false and add a layout with the fields that you want. Here is a code sample:
xamDataGrid.FieldLayoutSettings = new FieldLayoutSettings(); xamDataGrid.FieldLayoutSettings.AutoGenerateFields = false; xamDataGrid.FieldLayouts.Add(new FieldLayout()); xamDataGrid.FieldLayouts[0].Fields.Add(new Field("Value", obj1.Label));
Hope this helps.
Diyan Dimitrov
Hey Diyan,
Here is an example of what I mean. Lets say I make a call to some service and get back an xml response with some info. I deserialize that response into a number of objects, which can be different each time the call is made.
Lets say each object has two properties, Label and Value. I would like the grid to show columns with labels that match the value of Label with values from Value. So if I have a two objects, obj1 and obj2, that look like this:
obj1.Label = "Parts"
obj1.Value = "17"
obj2.Label = "Parts"
obj2.Value = "12"
I would like a grid that looks like:
Parts
17
12
If I bind my data source to the grid, the grid automatically just uses the object's properties to create the columns, so I see columns of Label and Value:
Label Value
Parts 17
Parts 12
I am assuming that I cannot achieve what I want just via xaml. Do you have an example of what I am looking for?
Let me know if I am not clear.
I am not sure exactly what you mean, but the grid will automatically generate the columns/fields depending on your data source. You don’t need to specify the columns/fields unless you want to do some customizations to them i.e. to change the label of the column. Hope this helps!
Hey guys, any tips/samples demonstrating this?
