830
set Width Field
in XamDataGrid in 'Loaded event seven field like this:
 private void xdgBase_Loaded(object sender, RoutedEventArgs e)
            XamDataGrid xdg = sender as XamDataGrid;
            try
Field
fieldTmp;
fieldTmp = xdg.FieldLayouts[0].Fields[
"StazioneCollegata"];
fieldTmp.Label =
"Stazione Collegata";
fieldTmp.ToolTip = "Stazione Collegata";
septum as the width of the cell?
  • 27093
    You can set this by using either the LabelWidth or the CellWidth proeprties of the FieldSettings class. You can access them like so:
    Field fieldTmp;
    fieldTmp = xdg.FieldLayouts[0].Fields["StazioneCollegata"];
    fieldTmp.Label = "Stazione Collegata";
    fieldTmp.Settings.LabelWidth = 200;
    //or
    fieldTmp.Settings.CellWidth = 200;
    Let me know if you need any further help with this.
    Sincerely,
    Petar Monov
    Developer Support Engineer
    Infragistics Bulgaria
    www.infragistics.com/support
