285
Allow editing a XamDataTreeNode while IsDraggable is true.
I am having trouble allowing a xamdatatree node to enter the editable state while the IsDraggable property is set to true in the node layout. I would like the node to automatically be editable when it is clicked on by the user. When the IsDraggable property is set to true this does not appear to work when the user clicks on the node. When the IsDraggable property is not set to true, it does work.  The IsF2EditingEnabled and the IsEnterEditingEnabled seem to work fine regardless of the value of the IsDraggable property. Is this behavior intentional? If necessary I can come up with a simple example if you all are unable to re-create.
Chris
