I am trying to add buttons (or any other content) to the contentpanes of the XamDockManager. In order to do this, I subclassed ContentPane into ContentPaneEx) and PaneHeaderPresenter into PaneHeaderPresenterEx. To both, I added a ContentPresenter dependency property and called it ButtonContent.
I then created styles for both, taking the styles for ContentPane and PaneHeaderPresenter from DefaultStyles as templates. I changed the TargetType for each style to be that of the subclassed versions.
To the ContentPaneEx style, I replace PaneHeaderPresenter with PaneHEaderPresenterEx and added a binding for the ButtonContent property of the PaneHeaderPresenterEx. To the PaneHeaderPresenterEx style, I added the following contentpresenter:<ContentPresenter x:Name="PART_ButtonContentPresenter" DockPanel.Dock ="Right"Visibility="{Binding Path=Pane.ButtonContentVisibility, RelativeSource={RelativeSource TemplatedParent}}"Content="{Binding ButtonContent, RelativeSource={RelativeSource FindAncestor, AncestorType={x:Type Views:PaneHeaderPresenterEx}}}"DataContext="{Binding DataContext, RelativeSource={RelativeSource FindAncestor, AncestorType={x:Type Views:PaneHeaderPresenterEx}}}"/>
Here is my implementation:<Views:ContentPaneEx x:Name="collateralPane" Header="Heading" AllowClose="False" AllowInDocumentHost="False" AllowFloatingOnly="False" CloseButtonVisibility="Collapsed" WindowPositionMenuVisibility="Collapsed"><Views:ContentPaneEx.ButtonContent><StackPanel Orientation="Horizontal"><ToggleButton IsChecked="False" Style="{StaticResource style}" /><ToggleButton IsChecked="True" Style="{StaticResource style2}" /><ToggleButton IsChecked="False" Style="{StaticResource style3}" /></StackPanel></Views:ContentPaneEx.ButtonContent></Views:ContentPaneEx>
(I left the rest of the xaml out.)
When I run the app now, docked/pinned panes come up fine, but when I drag these panes off and float them, I get an empty window. In the output, I see the following databinding error:
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'RelativeSource FindAncestor, AncestorType='Infragistics.Windows.Controls.ToolWindow', AncestorLevel='1''. BindingExpression:Path=IsActive; DataItem=null; target element is 'Button' (Name='CloseButton'); target property is 'NoTarget' (type 'Object')
What am I doing wrong? How can I fix this?
Thanks in advance!
Thanks again.
Found the problem. Stupid error on my end.
In ContentPaneEx and PaneHeaderPresenterEx, I had added: DefaultStyleKeyProperty.OverrideMetadata
Removing it fixed the problem.
