This is something odd, when a contentpane is undocked and moved into a floating state PRISM V4 RegionManager seems to loose a reference to that ContentPane's injected region, causing some of my code that depends on this to fail.
Note: Re-docking seems to add the region back into the RegionManagers collection.
Any suggestions? I can probably figure this one out or a way around it but i wanted to bring it to your attention and see if perhaps you already have a solution.
Use this Prism region adapter for the XamDockManager
http://brianlagunas.com/2012/09/12/xamdockmanagera-prism-regionadapter/
I'm not sure I follow. There really is no distinction. The xamDockManager creates the floating panes whenever it needs them to host a floating splitpane. If you needed to somehow distinguish you could set a property on your root splitpane that you create at design time and if that property isn't there then it's one that has been created but then again if you load a layout the dockmanager will create the panetoolwindow as needed.
This seems to have done the trick. One more question though, what is the best way to see if a floating window is being created vs. the standard "ToolWindowLoaded" events that are fired during initialization for my docked SplitePanes?
Floating panes are hosted in a separate WPF Window so you probably need to handle the ToolWindowLoaded event and use the RegionManager.SetRegionManager method to set the region manager on the e.ToolWindow.
Same Problem here!
How can I fix this?Thanks in advance!
