new hand ask question:how to set background like this pic?
There is currently no way to selectively hide axis labels. If your labels are a part of the data source, then you would have to either set the weekend labels to an empty string, or create an adapter that filters out weekends from your data.
I hve a question in XamLine Chart. I am using Date in Label for X-Axis and set Autorange to false. I specified the Minimum,Maximum and Unit for the range and the chart shows correctly. What I need is I want to remove weekend Labels from the X-Axis. Is it possible and how I can do so? Please reply.
Thanks & Regards,
Mukesh
i have lot of question ,sorry ! ^_^
returnValue.ChartType = ChartType.Line;
if (yKey == "Result")
brush = new SolidColorBrush(Colors.Blue);
returnValue.Fill = brush;
else
write what?
1.the Result was middle line ,other line was dotted line ,what should i do .
2.when i set xamWebChartPkg.Axes[1].Unit = 0.001;
it warning:Yaxis unit value too small.
but i must set the unit with small,otherwise the space was too small.
i see,thanks for you patience again!
AutoRange should be set to False. Otherwise, Min, Max and Unit are automatically calculated.
