435
Xamdatagrid binding
Can I bind xamdatagrid to Expando/dynamic object?
The datastructure/ datasource used for binding is not defined at design time. its available only at run time.. Also the same datastructure should be used for binding pivot grid also??
Appreciate a response with some samples..
Thanks!!
  • 27093
    I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
  • 27093
  • 27093
    I have been looking into your enquiry and I am actually not familiar with the Expando objects you mentioned. As I looked into them I assume they are not widely spread and that is why I was wondering if you could provide me with a sample project which I can use for testing. If you can load up such data into the Microsoft DataGrid control we should be able to use the data  source as well, even though there aren’t specific testing included for this particular data source.
