445
Horizontal scrollbar MIA
I have a xamDatagrid placed in a grid control, on a user control, with some grid splitters for resizing my columns and rows...
Why is my horizontal scrollbar not showing up at all ever?
<UserControl x:Class="WorksheetControl"
             xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
             xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
             xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
             xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
             xmlns:ig="http://infragistics.com/DataPresenter"
             mc:Ignorable="d"
             d:DesignHeight="500" d:DesignWidth="300">
    <Grid>
        <Grid.ColumnDefinitions>
            <ColumnDefinition Width="300"/>
            <ColumnDefinition Width="*"/>
        </Grid.ColumnDefinitions>
        <Grid.RowDefinitions>
            <RowDefinition Height="*"/>
            <RowDefinition Height="300"/>
        </Grid.RowDefinitions>
        <ListBox Name="lbFiles" Grid.Row="0" Grid.Column="0" Margin="0,0,0,5">
        </ListBox>
        <ig:XamDataGrid Grid.Row="1" Grid.Column="0" DataSource="{Binding CalculatedValues}">
            <ig:XamDataGrid.ContextMenu>
                <ContextMenu>
                    <MenuItem Header="Add Calculated Value" Click="AddCV_Click"/>
                </ContextMenu>
            </ig:XamDataGrid.ContextMenu>
            <ig:XamDataGrid.ViewSettings>
                <ig:GridViewSettings />
            </ig:XamDataGrid.ViewSettings>
            <ig:XamDataGrid.FieldLayoutSettings>
                <ig:FieldLayoutSettings AutoGenerateFields="False" SelectionTypeCell="Default" SelectionTypeField="Single" SelectionTypeRecord="Extended" />
            </ig:XamDataGrid.FieldLayoutSettings>
            <ig:XamDataGrid.FieldLayouts >
                <ig:FieldLayout IsDefault="True" >
                    <ig:Field Name="Name" Label="{Binding Name}"/>
                    <ig:Field Name="Value" Label="{Binding Value}"/>
                    <ig:Field Name="Units" Label="{Binding Units}" />
                </ig:FieldLayout>
            </ig:XamDataGrid.FieldLayouts>
            <!-- Enable field selection and disable cell editing-->
            <ig:XamDataGrid.FieldSettings>
                <ig:FieldSettings LabelClickAction="SelectField" AllowEdit="True" CellClickAction="SelectRecord" CellContentAlignment="LabelAboveValueAlignCenter" />
            </ig:XamDataGrid.FieldSettings>
        </ig:XamDataGrid>
        <GridSplitter ResizeDirection="Rows" Grid.Column="0" Grid.Row="0" Width="Auto" Height="5" HorizontalAlignment="Stretch" VerticalAlignment="Bottom"/>
        <GridSplitter Grid.Column="1" Grid.RowSpan="2" Width="5" HorizontalAlignment="Left" />
    </Grid>
</UserControl>
  • 138253
    It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking through your post and I used the code you have provided and it seems like that everything works ok on my side. If my sample doesn’t satisfies all your needs feel free to modify it, so it reproduces your behavior and send it back to me for further investigation.
    WpfApplication111.zip
