120
Empty value in XamComboEditor if value doesnt exists in ComboBoxItemsProvider
I need display empty value in xamdatagrid if saved value GUID doesnt exists in ComboBoxItemsProvider.
But I still see GUID value.
THX for help.
 foreach (DataRow dr in dt.Rows)
                provider.Items.Add(new Infragistics.Windows.Editors.ComboBoxDataItem(new             Guid(dr["id"].ToString()), dr["name"].ToString()));
Style s = new Style(typeof(Infragistics.Windows.Editors.XamComboEditor));
Setter set = new Setter(Infragistics.Windows.Editors.XamComboEditor.ItemsProviderProperty, provider);
 s.Setters.Add(set);
 field.Settings.EditorStyle = s;
  • 138253
    It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking through your post and I suggest you use the following code in your XamComboEditor’s EditModeEnding event:
    XamComboEditor combo = (sender as XamComboEditor);
    if (combo.Value.ToString() != String.Empty)
        if (!(combo.ItemsProvider.ItemsSource as ObservableCollection<Guid>).Contains(Guid.Parse(combo.Value.ToString())))
            combo.Value = String.Empty;
