Hi, i'm trying to write simple application in WPF which can open shp files add it to layers and display them (with possiblity to disable/enable particular layers), but i have big problem with adding layers after boot...
Example 1 (this code don't render file):
private string filename=null;
public MainWindow()
InitializeComponent();
private void button1_Click(object sender, RoutedEventArgs e)
// Create OpenFileDialog
Microsoft.Win32.OpenFileDialog dlg = new Microsoft.Win32.OpenFileDialog();
// Set filter for file extension and default file extension
dlg.DefaultExt = ".shp";
dlg.Filter = "Text documents (.shp)|*.shp";
// Display OpenFileDialog by calling ShowDialog method
Nullable<bool> result = dlg.ShowDialog();
// Get the selected file name and display in a TextBox
if (result == true)
filename = Path.GetDirectoryName(dlg.FileName) + "\\" + Path.GetFileNameWithoutExtension(dlg.FileName);
MapLayer WorldLayer = new MapLayer();
ShapeFileReader reader = new ShapeFileReader();
reader.Uri = filename;
WorldLayer.Reader = reader;
WorldLayer.ImportAsync();
xamMap1.Layers.Add(WorldLayer);
MapNavigationPane navPane = new MapNavigationPane();
navPane.SetValue(XamDock.EdgeProperty, DockEdge.InsideRight);
navPane.Margin = new Thickness(10);
xamMap1.LogicalChildren.Add(navPane);
Example 2 (this code renders file):
And here is XAML file in both cases the same:
<Window x:Class="testwczytywania.MainWindow"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
Title="MainWindow" Height="350" Width="525"
xmlns:ig="http://schemas.infragistics.com/xaml">
<Grid>
<Grid.RowDefinitions>
<RowDefinition Height="26*" />
<RowDefinition Height="285*" />
</Grid.RowDefinitions>
<Button Content="Button" Height="23" HorizontalAlignment="Left" Name="button1" VerticalAlignment="Top" Width="75" Click="button1_Click" />
<Grid Grid.Row="1">
<ig:XamMap HorizontalAlignment="Left" Margin="11,37,0,0" Name="xamMap1" VerticalAlignment="Top" MinHeight="299" MinWidth="491" />
</Grid>
</Window>
Hi Morpheus,
Try the following: add the WorldLayer to XamMap's Layer collection and then call ImportAsync. e.g.:
xamMap1.Layers.Add(WorldLayer);WorldLayer.ImportAsync();
Ivan Kotev
