Is there a way to get rid of the black horizontal line that shows up when the ribbon bar is minimized?
The reason is that you don't have any tabs in your xamRibbon. The templates weren't set up to handle this because the MS Office UI guidelines indicate that tabs are a requirement when using the Ribbon UI. Even in Office 2010 where you are allowed to hide tabs it does not allow you to hide all the tabs. So while we can adjust the templates to allow for this (it should be in an upcoming SR) it would seem that technically this violates your license agreement with MS to use the Ribbon UI in your application.
Hi!
I have the same problem, here's the code
<igRibbon:XamRibbonWindow
x:Class="Window1"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:igRibbon="http://infragistics.com/Ribbon"
xmlns:igEditors="http://infragistics.com/Editors"
xmlns:igWindows="http://infragistics.com/Windows"
Title="Window1" Height="397" Width="587">
<igRibbon:RibbonWindowContentHost>
<igRibbon:RibbonWindowContentHost.Ribbon>
<igRibbon:XamRibbon x:Name="myRibbon" DockPanel.Dock="Top" Theme="Office2k7Silver">
</igRibbon:XamRibbon>
</igRibbon:RibbonWindowContentHost.Ribbon>
</igRibbon:RibbonWindowContentHost>
</igRibbon:XamRibbonWindow >
I am just checking if this is still an issue for you.
Please let me know if you require any further assistance on the matter.
Sincerely,
Krasimir
Developer Support Engineer
Infragistics, Inc.
www.infragistics.com/support
I have been looking into the issue that you described in your post and I need some clarification on the matter. When the XamRibbon’s IsMinimized property is set to True there are no black lines.
Would you please send me a sample application or screenshot to clarify which black line you are referring to?
