I am looking for the event which I can use to do something if the Mouse is over a new Record in a grid. I don't want to use "RecordActivated", because I do not want to click on the Record. Which event is fired if a Record is "highlighted"?
Thanks for helping!
Gawain
Cheers, that helped a lot!
Hello Gawain,
I am just checking if my post was helpful for you.
If you require any further assistance please do not hesitate to ask.
Sincerely,
Krasimir
Developer Support Engineer
Infragistics, Inc.
www.infragistics.com/support
The event that you can use is DataRecorPresenter’s MouseEnter event. You can handle this event by creating a style for the DataRecordPresenter with an EventSetter for this event. You can put the style in the Resources section of the XamDataGrid as follows:
<igDP:XamDataGrid.Resources>
<Style TargetType="{x:Type igDP:DataRecordPresenter}">
<EventSetter Event="MouseEnter" Handler="Record_MouseEnter"/>
<EventSetter Event="MouseLeave" Handler="Record_MouseLeave"/>
</Style>
</igDP:XamDataGrid.Resources>
And in the code behind the event handler looks like this:
void Record_MouseEnter(object sender, MouseEventArgs e)
I have created a sample application for you that demonstrates the described above.
If you require any further assistance on the matter please do not hesitate to ask.
