Is there a simple way to put the label in or around the pie chart instead of in a legend?
Hello DLVendor,
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
If this is what you were looking for please verify the answer so it helps other users as well.
Thank you for your post. I have been looking through you requirement however the XamChart Pie Series can only show markers displaying the values that they represent and only inside the pie slices. I can suggest you check out our new XamDatachart’s new Pie version which allows for different label setting like the ones you are looking for. Here is a link to its Silverlight version which has the same settings for the labels:
http://samples.infragistics.com/sldv/RunSamples.aspx?cn=data-chart#/data-chart/pie-chart
If you have any further questions on this matter please do not hesitate to ask.
