<igRibbon:RibbonGroup ItemsPanel="{StaticResource ItemsViewPanel}"> <GroupBox Content="{Binding Path=Layout.LayoutParameters}"/> </igRibbon:RibbonGroup>
The Static resource is<ItemsPanelTemplate x:Key="ItemsViewPanel"> <igRibbon:ToolHorizontalWrapPanel IsItemsHost="True" /> </ItemsPanelTemplate>And the DataTemplate for the Binding Property is:<DataTemplate DataType="{x:Type MyType}"> <igRibbon:ToolHorizontalWrapPanel> ....
The Behaviour is, that changes of the Bound Property results in an error if the value is reset .
I am checking if this is still an issue for you.
If you require any further assistance please do not hesitate to ask.
Sincerely,
Krasimir
Developer Support Engineer
Infragistics, Inc.
www.infragistics.com/support
I have been looking into you issue and I am not sure I completely understand what you are trying to achieve. Would you please, clarify which property gives you an error when its value is reset? Is it the property that the GtoupBox’s Content property is bound to and if possible would you sends me a sample application that demonstrates the scenario that you described in your post?
