360
AutoGenerateFields = "False"
Hello
   Is it possible to control what fields are added to a card?  I wish to show and hide fields as the state of my object changes.
Thank you,
Patrick Brown
  • 138253
    Hello Patrick,
    It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post and I created a sample project for you with the functionality you want. Basically I used a Converter for the Visibility of the CellPresenterStyle and returned Collapsed or Visible depending on one of the Record’s Cell’s Value.
    xamDataCardsFields.zip
  • 360
    Hi
       Found part of the answer in FieldLayoutSettings, now, the remaining part, what is the easiest way to use binding to show the others when they apply?  I have seen examples where a globally defined object is used as a binding source, is there a way to do this off of the data bound to the cell editor?
    Patrick
