210
XAxis Font scale
 I have a chart (Scatter/Line) and I can't seem to change the size of the font along the xAxis.  It always appears to be very small.  I added a font size parameter to the Axis and it didn't do anything:
<igCA:Axis Name="xAxis" AxisType="PrimaryX" AutoRange="True" StrokeThickness="1" >
<igCA:Axis.Label>
<igCA:Label Format="{}{0:0%}" FontSize="16" ></igCA:Label>
</igCA:Axis.Label>
</igCA:Axis>
It is not dislaying the 16 pt font, but rather something very small....
Steve
  • 739
     Hi Steve,
    The xamChart has auto resizing algorithm for axis labels to prevent overlapping of labels.   So if there is a risk that labels will overlap, the labels font size will be automatically changed. It will usually happened if the unit value is small and there is not enough space for labels. If you want to disable this auto behaviour, you can use the following code:
       <igCA:Axis.Label>
          <igCA:Label Format="{}{0:0%}" FontSize="40" AutoResize="False" />
       </igCA:Axis.Label>
    </igCA:Axis>
    The AutoResize property of the label is set to “False” which will prevent overlapping.
    GoranS
