After upgrading to Infragistics WPF4 v 10.3.20103.2196, we got some strange behavior.
Application main window is XamRibbonWindow.
If that window is minimized and then maximized, close, minimize and restore buttons in window title bare are no longer visible?
This did not happen in version WPF3 2010.10.2
Any help would be appreciated.
This will be resolved in the next service release which should be out late June / early July. To find out when service releases will be available please see:
http://ko.infragistics.com/support/service-releases.aspx
I will create a case for you so that you will automatically be notiffied then the fix is released.
Valerie
Yes, Im using Windows 7 with Aero turned on.
Do you have any timeframe about when the issue might be resolved?
Thank you
There is an open issue for this when using the Aero Theme on Windows 7. What operating system are you using and what theme is set for Windows?
