We are using XamDockMananger within a Prism4 Application. When we hide the Shell (our main window) after undocking an open (Split/Tabbed)Pane we don't want to see the docking indicators because there is nothing to dock to.
How can we disable the Docking Indicators when our "Docking-Window" is hidden ?
Andrew suggested that a development issue be logged for this behavior; docking indicators being visible when the main window is hidden and the associated docking window is undocked.
I’m in the process of doing that and will contact you directly concerning the status of that development issue thru a case I have created for you.
You will hear from me shortly thru the case.
Okay,
if it sounds like a bug: How to go on ?
We've created a crazy workaround with many bells and whistles but this is NOT satisfying...
Will you check this and open an error ticket ?!
The docking indicators on the main window should not be displayed if the associated window is not shown. This sounds like a bug.
